Author: Subject: fusebox
beaver34
posted on 19/10/10 at 05:16 PM Reply With Quote
fusebox
hi,
i have a 10 blade fusebox what is the best way to run from one power source and split to 10?
rubbish pic i know
RazMan
posted on 19/10/10 at 05:23 PM Reply With Quote
You don't really want to split 1:10 and will need more like 2 banks of 5. One for permanent feed and the other for switched feed. Either way you can often run a common feed to each bank using the internal busbar (if it has one) Each feed will have to be individually fused as a safeguard.
Raz
beaver34
posted on 19/10/10 at 05:28 PM Reply With Quote
im running from the cutoff switch to this, so that is the ignition switch really?
there is no internal to the fuse box just 10 blade fittings
RazMan
posted on 19/10/10 at 05:48 PM Reply With Quote
IIRC that will not pass IVA as you need lights, hazards and horn working with the ignition switched off ...... or are you wiring a track-only car?
So you have 10 connections each side? You can split the main feed wire into 10 smaller feeds but tbh I would choose a more suitable fusebox - much easier. This one has a side entry to a 6mm connection.
10 Way Blade Fuse Box Holder HIGH QUALITY on eBay (end time 19-Dec-10 20:35:33 GMT)
[Edited on 19-10-10 by RazMan]
Raz
beaver34
posted on 19/10/10 at 05:54 PM Reply With Quote
its already on the road, but the above is made for iva for a reason so i will make them permanent live, going to have a look at my fuse box now see what its like
thanks for the help
