Author: Subject: 2001 busa
dilley
posted on 22/10/10 at 07:25 PM Reply With Quote
2001 busa
AGAIN!!!! I have a wiring diagram that shows a seperate fuel pump and relay, my 2001 loom appears to only have one plug. It has the fuel pump bolted to the throttle bodies, so, should it only have the one plug?
bob tatt
posted on 22/10/10 at 07:28 PM Reply With Quote
mine does and works fine with the original pump and a low pressure pump feeding the swirl pot.
dilley
posted on 22/10/10 at 07:36 PM Reply With Quote
I have removed what I thought was the side stand/flasher relay and I think that may have been fuel pump too?
dilley
posted on 22/10/10 at 08:50 PM Reply With Quote
problem solved... my wiring digram is wrong, 1 plug to throttle boddies and then there is a seperate loom from that to the pump! phew!!!
