Author: Subject: earth points
dilley
posted on 26/10/10 at 06:35 PM Reply With Quote
earth points
I have almst completed my wiring, all earth wires on my busa loom seem to be connected to one main earth wire running through the loom, rather than extend all these earth cables back to the main can I just earth to chassis? I can have 2 main chassis earth points, I would feel a lot happier having the regulator/rectifier earthed to chassis as close as possible.. what do you think?
adithorp
posted on 26/10/10 at 06:41 PM Reply With Quote
Yes, shouldn't be a problem. Make sure to put a main large earth lead from the battery to both the chassis and the engine.
adrian
http://jpsc.org.uk/forum/
dilley
posted on 26/10/10 at 06:43 PM Reply With Quote
I understnd the battery to chassis earth, does it really need one to the engine when it is solid mounted to the chassis? my battery is about 2 meters in cable from my engine..
spiderman01980
posted on 26/10/10 at 06:44 PM Reply With Quote
yeah that should be ok! ones the battery is earthed to the chassis, the whole chassis becomes an earth!
adithorp
posted on 26/10/10 at 06:56 PM Reply With Quote
Shouldn't be needed then but any paint etc at the mounting points will be a problem. Get around that by attaching an earth strap between the engine and a good chassis earth.
adrian
omega0684
posted on 26/10/10 at 07:20 PM Reply With Quote
your engine is bolted direct to the chassis with no rubber mounts to absorb vibration from the engine? i bet your teeth are going to chatter a bit?
Daddylonglegs
posted on 26/10/10 at 07:42 PM Reply With Quote
Beat me to it!
I was always told that it is good practice to have a seperate earth from engine block to chassis anyhow just to be sure.
ReMan
posted on 26/10/10 at 09:12 PM Reply With Quote
er Yes, but we prefer to call it feedback
Davey D
posted on 27/10/10 at 08:26 AM Reply With Quote
Arent all BECs setup using a solid mounting from engine to chassis?
ReMan
posted on 27/10/10 at 12:54 PM Reply With Quote
Yes most
