Author: Subject: how do i know what size battery cable to go for?
blakep82
posted on 4/5/11 at 06:00 PM Reply With Quote
got the battery box sort of in the middle of the car, and the starter over the opposite side at the front. its 1.5 and then some across, so maybe 3m total depending on how its routed?
starter is standard VAUXHALL astra job, then its only lights, gauges, and ignition, no complicated electric washers or wipers or anything like that.
how much is the starter going to draw on cranking? assuming it might take a little longer than most if its cold?
i haven't got the original cables off the engine to ceck what they were
[Edited on 4/5/11 by blakep82]
________________________
daviep
posted on 4/5/11 at 06:17 PM Reply With Quote
Personally I'd go large for the battery to starter and for the main engine earth, I'd use 40mm2 539/0.3, which should be good for 300amps.
Davie
snowy2
posted on 4/5/11 at 07:27 PM Reply With Quote
Originally posted by blakep82
starter is standard ford astra job,
Now that is a car i want to see,
a starter can draw 1000A on start up up to 1500A is possible (only for a short period, then it will settle down to a hundred or so,)
normal starter cable will be fine and you can order it in any length you require it for very cheaply. with ends fitted.
sometimes you are the pigeon, most of the time the statue.
blakep82
posted on 4/5/11 at 07:32 PM Reply With Quote
oops, yeah vauxhall astra! lol thats what i get for building a car with parts from so many different cars both ford and vauxhall, and bedford, kawasaki,
as much as 1000A?! wow. i guess if i can find out what was used on the astra, i'd go for that?
