Author: Subject: Rover V8 Starter cable thickness
Irony
posted on 26/5/11 at 09:13 PM Reply With Quote
What thickness wire should I use from the battery to the starter motor and from the battery to the engine then chassis? I looked at getting pre made jobbes from Vech Wiring Products but the pre-mades seem to top out at 19mm squared. I would like to make my own but fearful of doing a bad crimping job. Is this crimping easy and with what tool?
Oh the Positive cable to the starter will be about 500mm to 600mm and the earth about 450mm - 500mm?
v8kid
posted on 26/5/11 at 11:02 PM Reply With Quote
Umm! It all depends. Assuming you are using a standard starter with a standard motor 16mm would be OK but 25mm would be marginally better if the battery had a higher international resistance (loosly approximating to capacity).
Crimping is dead east however. Get tinned lugs from tool station for example - they will come in 10 16 and 25 mm sizes. Get a bit of angle iron and put it corner down in a vice jaws Put the lug on the cable and rest it in the angle iron and then whallop it with a pin punch - around 8to10mm once only with a club hammer.
Perfect every time once you have the knack.
Hmm this is a case where a pic is worth a k words I think!
Back to the cable size. As an example I have a high compression v8 with a motorcycle battery to start it. Using 25mm cable with a geared starter motor works perfectly. If I used a car battery possibly I could get away with 16mm. If the standard starter was used I'd need 25mm plus the car battery.
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
v8kid
posted on 26/5/11 at 11:07 PM Reply With Quote
Btw you earth lead seems rather long
Irony
posted on 27/5/11 at 07:09 AM Reply With Quote
I was probably being a little over zealous with the length of the earth lead. I think I will go for the 'make your own route'. Does anyone have any pics of this process?
Thanks for the advice!!
Irony
posted on 27/5/11 at 02:36 PM Reply With Quote
no one got anything else to say?
Paul (Notts)
posted on 27/5/11 at 03:22 PM Reply With Quote
My starter motor cable is Bl**dy thick and about 2m long. Soldered fittings on the ends using my brazing torch.
Starts first time .
Paul
