ed1max
posted on 20/7/11 at 03:19 PM |
Rad fan switch
Hi all,
I've got a 16600X flow in my westie,can anyone tell me the correct temp range should be on the fan switch.
Regards and thanks for any advice.
Eddie
shindha
posted on 20/7/11 at 03:51 PM |
Mine runs between 80 - 90 degrees but I have to have the fan on in traffic especially if the weathers warm - i have a manual switch usually switch it
on from the word go in hot weather.
posted on 20/7/11 at 03:58 PM |
Somewhere around 91 to 97c, no point in having it lower than the thermostat start to open temp, on at 95 off at 93 should be fine.
It should be fitted in the cooling circuit on the rad side of the thermostat never before the thermostat, ideally in the rad itself failing that
in the top hose.
