Author: Subject: What fuse box???
AndyW
posted on 21/8/11 at 07:43 AM Reply With Quote
What fuse box???
Morning all,
Fitted starter yesterday (after alot of grining of the ally tray) and started to fit all the power cables. So, my question for today is, what fuse box are you gus using? I already have a Premier loom with its own 2 fuse box's so just need to add one to take power in from the battery. What size will I need.
Any links, pics welcome as always!!
big_wasa
posted on 21/8/11 at 08:11 AM Reply With Quote
Starter and alternator dont need a fuse. I would use a seperate fuse box from your prem loom for your efi. The last one I did for some one just had a fused feed for a coil and thats not enough for the full efi.
big-vee-twin
posted on 21/8/11 at 08:17 AM Reply With Quote
All you need is a 40 amp in-line fuse and install it into the 4mm red wire that supplies the loom.
You don't need to fuse the starter motor or the charge wire.
I have added another 4 way fuse holder like those Alan fits to his loom switched by a relay which the powers the fuel pump, injectors and coil.
The relay will be controlled by the ECU.
http://www.triangleltd.com
AndyW
posted on 21/8/11 at 08:25 AM Reply With Quote
OK, thanks. I have the battery leads as picture below. Im now confusing myself!!
Dont you just love wiring.......
big_wasa
posted on 21/8/11 at 08:29 AM Reply With Quote
Ok if you want a main fuse to feed the prem loom just get a maga fuse.
AndyW
posted on 21/8/11 at 08:58 AM Reply With Quote
That might be an option, on the diagram above tho', where would I connect "E" to?
big_wasa
posted on 21/8/11 at 08:59 AM Reply With Quote
Yes E to one side of the maga fuse and the prem loom to the other side.
[Edited on 21/8/11 by big_wasa]
AndyW
posted on 21/8/11 at 09:02 AM Reply With Quote
Thanks Warren.
big_wasa
posted on 21/8/11 at 11:09 AM Reply With Quote
You will still want another fuse box for the mondeo efi. 6 way should do.
AndyW
posted on 21/8/11 at 11:55 AM Reply With Quote
Cheer again!! Going to order one this week, then the real fun starts as I attemp to do the wiring. The kids are away next weekend so got all Sat and Sun to work on it! Bit nervous to be honest!!!
This type is the same as the premier, will this be ok JJC Standard Blade Fuse Box 6 Way Panel Mount FBB6U | eBay
[Edited on 21/8/11 by AndyW]
big-vee-twin
posted on 21/8/11 at 12:45 PM Reply With Quote
That's fine
posted on 22/8/11 at 11:27 AM Reply With Quote
As I've mentioned before the Nissan Note has a nice fused thingy on the battery. Contains 4 fused 60 and 80amp (2 of each) outputs along with a 250amp for the starter.
