Author: Subject: Brake pressure switch
AdrianH
posted on 24/10/11 at 04:10 PM Reply With Quote
My brake pressure switch failed last week and it has taken me a while to get a replacement having to order one with a 1/8" NPT thread such as the Intermotor 51600.
I did a bit of a search online and found a few others complaining about how long they last and a mod to do to my wiring to add a relay so the 3.5 Amps of current goes through relay contacts rather then the switch it self.
May be worth considering if anyone has similar problems.
homepages.donobi.net/sufuelpumps/Other_Subjects/Electric al/General/Brake_Light_Relay.pdf
Came off an MG forum.
I did a slightly different wire up but works the same.
Adrian
[Edited on 24-10-11 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
ashg
posted on 24/10/11 at 06:34 PM Reply With Quote
had the same problem adrian. i got through 3 pressure switches before i gave up. i tried the relay option and it made naff all difference. i ended up fitting a micro switch to the brake pedal and it has been good as gold since.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
