JeffJeffers
posted on 20/11/11 at 03:31 PM |
Earth for ETB water sensor
I have bought a water temp sensor from ETB For my zetec engine. The sensor only has 1 terminal on it so the it earths through the body of the sensor.
The Zetec has a plastic thermostat housing. So what is the best way to earth the sensor?
big_wasa
posted on 20/11/11 at 03:38 PM |
Ive cut a little V groove on one of the hex flats and solderd an earth on. Ive then put a ring terminal under one of the three stat mounting bolts.
Edit just dont get it to hot !
[Edited on 20/11/11 by big_wasa]
mark chandler
posted on 20/11/11 at 04:05 PM |
Looks like a dash board gauge sensor to me, not an EFI one
Regards Mark
flibble
posted on 20/11/11 at 04:14 PM |
I did the same as wasa, only way I could think of and works
JeffJeffers
posted on 20/11/11 at 10:34 PM |
Thanks all.
Sensor is now wired up just needs testing.
posted on 20/11/11 at 10:57 PM |
Regards Mark
He'd be a bit stuck if he bought an EFI sensor when it's going to be wired to an ETB gauge!
mark chandler
posted on 20/11/11 at 11:21 PM |
Doh
Should have read the post, in which case use an EFI sender
