Author: Subject: Hazard lights
Worzey
posted on 29/4/12 at 09:59 AM Reply With Quote
Hazard lights
Need to get the car MOT'd but the Hazard lights have stopped working. I assume this is a fail if they don't work?
Indicators work fine but no hazards. Thinking it was the switch I got a replacement unit on eBay but no joy. I can only assume its the flasher unit or a wiring fault.
Problem is the car (not built by me) has the flasher relay bolted on a metal plate behind the steering column. The only way to reach it is to remove the dashboard and steering column assembly. Argh....
Looks like this is going to be a big job for what is probably a very simple fix What with work commitments I can't see me being able to get this done in quite a while.
Caterham R400
Ben_Copeland
posted on 29/4/12 at 10:06 AM Reply With Quote
Yes its a fail
[Edited on 29/4/12 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
steve m
posted on 29/4/12 at 04:16 PM Reply With Quote
Dave,
I can come over some time this week, and we can have a look
If the hazzards did work and now do not, i cant imagine its anything serious,
Have you "fiddled " with anything that could of misplaced a wire?
Do both sides indicators work in the correct fashion ?
If they do, I cant see it being a problem
Worzey
posted on 29/4/12 at 05:27 PM Reply With Quote
Steve, that would be great.
I've not touched anything since it went in the garage for the winter.
As far as I can see its got a single flasher relay for both indicators and hazards and as both indicators work fine and the hazards don't I suspect is a loose wire. The problem is that its all a bit inaccessible.
I've got some beer here waiting.
Caterham R400
