Author: Subject: How to wire up a 'push button' start?
yellowcab
posted on 29/4/12 at 03:12 PM Reply With Quote
Constantly loosing the key to my car, or leaving it places - and luckily found it every time so far, but its only a matter of time - so I want to rid the key altogether, and steering 'lock' that also comes with the crabby Sierra alloy setup.
How 'easy' is it to do? Done a search which didn't come up with anything concrete as such...
Also still trying to chase a the neutral light on the Busa loom, if anyone new is reading this? lol
Olz
snowy2
posted on 29/4/12 at 03:49 PM Reply With Quote
its not hard...i have been looking at doing the same thing myself. Its not desperately cheap either.
here is a site i have looked at for some ideas..
http://www.rotaryheaven.net/showthread.php?1154-DIY-Keyless-ignition-start-button-and-keypad
sometimes you are the pigeon, most of the time the statue.
tomgregory2000
posted on 29/4/12 at 03:57 PM Reply With Quote
so you want to be able to start your car without the need of a key?
so anybody will be able to start your with out a key
snowy2
posted on 29/4/12 at 03:59 PM Reply With Quote
NOPE the methods i have looked at use a keypad security system.
tul214
posted on 29/4/12 at 04:05 PM Reply With Quote
I did this. I had the red battery key which will deter most but then also put a simple key switch in the wire to the starter. Most of the time this was left live but could be turned off when needed. I suppose i still had a key but i needed one for the fuel cap anyway.
I suppose the best way would be to install a transponder type immobiliser. But even then you need the fob.
Mark
1.6 Raw Super6 sold
posted on 29/4/12 at 04:47 PM Reply With Quote
Couldn't you wire it to earth a relay which operates the starter ?
yellowcab
posted on 29/4/12 at 04:52 PM Reply With Quote
Im not particulary fussed about 'anyone' being able to start it, if someone was gonna steal it they push it away anyway, much quieter lol
jossey
posted on 29/4/12 at 04:59 PM Reply With Quote
it just replaces the ignition last turn on your current ignition. eaisest way to do it is to leave lock in but hide it under dash and glue key in so you dont lose it and then wire the starter to the starter live and negative. then you turn key to 3 and press start button. otherwise you need to replace the ignition barrel with switches for ignition and starter etc....
David Johnson
yellowcab
posted on 29/4/12 at 07:20 PM Reply With Quote
So I'd keep the key constantly turned at position 2 of three, and clue it in there, hide it behind the dashboard?
Will that not keep my fuel pumps constantly running? or am I mistaken?
(sorry if a daft question, not too hot on electronics)
ReMan
posted on 29/4/12 at 07:52 PM Reply With Quote
Youll need to repalce the sierra key switch with a new "master" power switch
and then add in your puch to start button or like this all in one very lightweight carbon one
http://www.nfauto.co.uk/all_switches.htm
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
yellowcab
posted on 29/4/12 at 07:57 PM Reply With Quote
Thanks for the link Col... Bookmarked!
owelly
posted on 29/4/12 at 07:58 PM Reply With Quote
Just fasten the key to the car with a bit of bathplug chain but hide it in a combination security box under the dash.
http://www.ppcmag.co.uk
yellowcab
posted on 29/4/12 at 08:00 PM Reply With Quote
Infact... Col, I'll take your reply as a volunteer to help me out to do it lol
ReMan
posted on 29/4/12 at 08:21 PM Reply With Quote
No prob, I can do electrical's a little bit
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
yellowcab
posted on 29/4/12 at 09:10 PM Reply With Quote
SOLD**
**this also relates to the gear indicator
AntonUK
posted on 30/4/12 at 09:11 AM Reply With Quote
Why. It leave the key in the ignition?
Build Photos Here
Xtreme Kermit
posted on 1/5/12 at 06:27 PM Reply With Quote
So here's the thing - How do you do a push button start where you just tap the button and it starts the car?
Not just replacing the start position with holding a button...
theduck
posted on 3/5/12 at 07:43 PM Reply With Quote
Thats far less simple and requires an ecu to do it.
Xtreme Kermit
posted on 3/5/12 at 08:21 PM Reply With Quote
Thought this might be the case.
Hmm bit of circuitry to run the starter until an rpm based output is used to disengage it - say 750rpm?
