Author: Subject: k series coolant temperature sensor
matty h
posted on 25/9/12 at 07:59 PM Reply With Quote
I am wanting to replace my coolant temperature sensor on a 1.4 k series engine as the car is running racetech gauges my question is what is the thread size.
thanks Matty
posted on 26/9/12 at 12:12 PM Reply With Quote
ISTR the Black Rover 2 wire Temperature sensor (nb they are colour coded) has the same characteristic as that used by a lot of aftermarket gear.
matty h
posted on 26/9/12 at 01:39 PM Reply With Quote
It is a blue sensor it does not seem to read correctly as it shows 80 degrees C after just starting.
Would this one work
http://www.rimmerbros.co.uk/Item--i-YCB10004EVA
Thanks Matty
westf27
posted on 26/9/12 at 04:17 PM Reply With Quote
http://www.eliseparts.com/products/show/33/227/stack-temperature-sender/
this one is blue and is the sensorfor the guage.The other one on the engine is a coolant sensor for the ecu to control fuelling and is normally black.
555
posted on 26/9/12 at 06:10 PM Reply With Quote
Yes--- the Black one.
Fuelparts do them loads on net & eBay for around a £10 search on Rover 25 sensor.
The Rover Rave CD workshop manual has the resistance -temperature curve for this sensor.
All the later models 25/45/75 only had one (black) sensor as the ECU drives the gauge which is the indirect cause of a lot of cooked engines as the ECU keeps the gauge planted on N between 75 and 118c..
There are also green and brown types from older older models.
[Edited on 26/9/12 by britishtrident]
posted on 27/9/12 at 12:43 AM Reply With Quote
Had loads of problems with Fuelpart sensors, might be why they've gone bust??
