daniel mason
posted on 9/2/13 at 09:31 PM |
electric waterpump help please
am getting to the stage where i need to sort the plumbing out,oil and fuel lines sorted,engine in etc. but i have come across a slight problem. what
controls the electric waterpump on my dry sumped busa? and when should it run? cheers
Phil.J
posted on 10/2/13 at 09:26 AM |
It should be wired to run all of the time the engine is running (as the mechanical pump it is replacing would have done).
snakebelly
posted on 10/2/13 at 11:56 AM |
Wot e said
iank
posted on 10/2/13 at 02:21 PM |
You can also keep running them after the ignition is off either timed, or until the water cools down. The ideas being that won't risk hot-spots
after you switch off. Probably only worth it if you're running a water cooled turbo.
Anonymous
