Author: Subject: relay wiring
beaver34
posted on 5/8/13 at 07:16 PM Reply With Quote
relay wiring
hi,
can someone clarify the wiring for a fuel pump relay as i think im going mad.
i have power from battery to fused no 30
85 to earth, 86 from on switch other side is from fuse box and 87 to the pos on the pump
nothing happens
its just a normal 30amp 4 blade relay as far as im aware, i purchased two one for each pump i run and neither are working
thanks
Daddylonglegs
posted on 5/8/13 at 07:50 PM Reply With Quote
Sounds OK wiring wise, if you have a multimeter check across 30-87 fro continuity when you energise the coil. If that works, try connecting 30 directly to 87 and see if the pump runs. If not then at least you can trace it from there.
HTH
beaver34
posted on 5/8/13 at 08:56 PM Reply With Quote
HTH
fixed, swapped 86 and 87 working fine on both now
omega 24 v6
posted on 6/8/13 at 09:27 AM Reply With Quote
Mmmm your originl explanation sounded fine. If swapping 86 and 87 solves the problem then 2 things spring to mind. Either your original explanation is NOT how you wired it OR you have ( there are 2 types A and B IIRC) an odd relay where the pin configurations are NOT a std layout.
You have to watch out for these when plugging into a std wired car relay socket .
beaver34
posted on 6/8/13 at 09:38 AM Reply With Quote
id been at work 12 hours before so its more than likley i confused myself somewhere along the wiring
Daddylonglegs
posted on 6/8/13 at 09:57 AM Reply With Quote
I'm with Gary on that one, still at least you got it sorted
big-vee-twin
posted on 6/8/13 at 03:30 PM Reply With Quote
Some relays have a diode across the coil therefore making them polarised
http://www.triangleltd.com
