nilocp
posted on 10/11/13 at 05:15 PM |
Tiger wiring loom
I have just got a Tiger wiring loom and it is for VW indicator stalks.
Which car do the donor bits from, and will they fit on a Sierra column.
Colin
femster87
posted on 10/11/13 at 05:57 PM |
Golf mk1.
nilocp
posted on 10/11/13 at 06:40 PM |
Thanks, can they be fitted to the Sierra column?
snippy
posted on 10/11/13 at 09:58 PM |
Depends on which Tiger model the loom was intended for. Some models use switch gear & steering column from the Golf, others use switch gear and
Column from the Sierra. The majority of Tigers models were Sierra based. I would have thought you could adapt the loom to wire it up to Ford switches
if thats what you have. I`ve just adapted an old Escort mk1 loom to work with Triumph Dolomite gauges etc.
femster87
posted on 10/11/13 at 10:10 PM |
You can rewire it to fit the seirra column. The wiring diagram for the Tiger r6 loom is in the link below. I think this will be the same for all tiger
looms.
http://www.tigerownersclub.co.uk/downloads/manuals/r6/24%20Wiring.pdf
http://www.tigerownersclub.co.uk/downloads/manuals/r6/S6%20Wiring%20Diagram.jpg
nilocp
posted on 13/11/13 at 08:46 PM |
Femster that was really useful. Unfortunately it is not the loom I have, but it has given me some clues.
Many thanks
Colin
