Jenko
posted on 29/12/13 at 05:59 PM |
Alternator wiring ford puma....
Mental block.....where do the two wires go on the alternator, not the main wires, but the small ones with the plug.
Thanks...Paul.
MY BLOG - http://westfieldv8.blogspot.co.uk/
theprisioner
posted on 29/12/13 at 06:50 PM |
I thought all I had to do was look at my folder and the answer would be apparent. No it is not obvious. I have looked at the ECU and it is not any
fancy charge control so it must be just the (NOT) charging light. In my case the charging light comes directly from the battery fuse box C3(3). The
alternator aux pins go directly to the battery fuse box. I have a copy of the ford TIS CD somewhere and if you need further information I can have a
dig.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Jenko
posted on 29/12/13 at 09:10 PM |
I figure one lead to switched 12v, and the other to a warning light on the dash....no idea which way around the wires are meant to go from the socket
on ...if there is anyway you can figure out which wire goes to 12v, then I'm sorted.....cheers.
monkeyarms
posted on 30/12/13 at 02:34 PM |
This is from the Ford TIS for a Puma, it might help ?
theprisioner
posted on 30/12/13 at 02:43 PM |
I was just about to post the same info, it appears there is some sort of charge control from the ECU, not sure what you do with it when you
don't have the stock ecu. There is also slight variations depending on year but don't appear that significant to me. I guess if you leave
off the charge control it will either charge too much or not at all!
....... remember that the alternator is still an alternator, if it’s not connected to the ECU it’ll revert back to the old school workings. If you
disconnect the 3 pin PCM plug from the alternator and it is charging again, this will show the alternator is being controlled by the PCM. This will
check if the alternator is still functioning
Here is an interesting thread:http://vehicle-electrics.co.uk/ford%20smart%20charge%20alternator.php
Alos I have connected a standard bulb thru 12V to my alternator charging wire and it works fine. The ecu connection as per diagram.
[Edited on 30/12/13 by theprisioner]
Jenko
posted on 30/12/13 at 10:10 PM |
Many thanks for the info....although the diagram is not that clear, it seems one of the wire for the two pin is to drive a charge error light, so
I'll take a flyer on which is which and report back....my digital dash has a spare warning light that is activated when its sees a 0v signal, I
will give this a try.
Paul.
theprisioner
posted on 31/12/13 at 12:24 AM |
Connect your lamp to C303 pin 1 and it will work I think.
Jenko
posted on 31/12/13 at 06:19 PM |
Update......did what was mentioned above and all seems well.....13.5v when engine started.. Charging light goes on when ignition on ,and off when
engine starts....I that concludes ALL engine wiring....time to get the bodywork on!.
