Author: Subject: led indicator relay
daveb666
posted on 3/1/15 at 11:11 PM Reply With Quote
led indicator relay
Wheres the cheapest play to get one of the relays that you need to slow down LED indicator s?
theduck
posted on 3/1/15 at 11:16 PM Reply With Quote
eBay normally
3 pin CF14 JL-02 Flasher Relay for Japanese car LED light blink flash 12V
loggyboy
posted on 3/1/15 at 11:22 PM Reply With Quote
99p?
urn Signal Flasher Blinker Relay 12V 2 Pin for Moorcycle LED Indicaor Ligh
Mistral Motorsport
CosKev3
posted on 3/1/15 at 11:58 PM Reply With Quote
http://m.ebay.co.uk/itm/161205422196?nav=SEARCH
Can recommend these adjustable ones, got one on my car.
Works with just my test light connected to indicator wiring
daveb666
posted on 18/2/15 at 08:06 PM Reply With Quote
Help please guys -
I bought both an adjustable one and normal one. I've tried both and I get nothing when I try the indicators and nothing when I try the hazard (apart from the hazard tell tale lighting up constantly).
If I swop back to the original ford one then all indicators work (all be it a bit fast).
I've seen a post from a few years ago where a chap said he had an issue like this until he removes the bulb from the sierra hazard button (whilst others have worked first off).
Any ideas anyone please?
theduck
posted on 18/2/15 at 08:17 PM Reply With Quote
Very odd, a fixed rate flasher should be exactly that, fixed rate.
daveb666
posted on 18/2/15 at 08:32 PM Reply With Quote
This was the other thread I found -
http://www.locostbuilders.co.uk/viewthread.php?tid=176526
CosKev3
posted on 18/2/15 at 10:52 PM Reply With Quote
The wiring is different on the adjustable ones compared to standard,terminals are in different positions.
So if you didn't realise this and have been just fitting them in the standard relay multi plug you could have knackered them.
snowy2
posted on 19/2/15 at 11:31 AM Reply With Quote
I use a Honda motor bike relay. About £8 and works fine even though only the fronts are LED's
sometimes you are the pigeon, most of the time the statue.
Chris_Xtreme
posted on 19/2/15 at 01:38 PM Reply With Quote
I'd agree with this, on mine it wasn't a straight swap, the pins on the led relay are different. Compare the wiring numbers on the 2 relays.
daveb666
posted on 20/2/15 at 09:25 AM Reply With Quote
Sorted. Pins were he opposite way round as you said.
