Author: Subject: starter motor wiring puzzle
mk85
posted on 11/1/15 at 12:53 AM Reply With Quote
Am trying to find info on wiring my starter up. I have a Nissan engine with an ecu. I have purchased my ignition switch and have one of the terminals labeled for the starter. Now on the starter motor I have the main power lead and one small cable. I presume the small goes to the ignition switch and power direct to the batter as it has the terminal on the end of the cable.
Is there any idiots guide to this side of it.
thanks people
posted on 11/1/15 at 09:56 AM Reply With Quote
Sounds like you have bit sussed. Connect the big fat wire to the battery and the small one to the switch, turn the key and see what happens.
posted on 11/1/15 at 11:29 AM Reply With Quote
As already suggested but it might be worth fitting a relay to take any heavy loads off of the switch
snowy2
posted on 13/1/15 at 11:25 AM Reply With Quote
The starter solenoid is a relay.....it should not need a relay to opperate it......modern cars that show relays in the cct are almost start inhibit relays used with immobiliser systems.
sometimes you are the pigeon, most of the time the statue.
mk85
posted on 13/1/15 at 11:44 AM Reply With Quote
thanks
adithorp
posted on 13/1/15 at 12:19 PM Reply With Quote
Starter soleniod has quite a big draw. Technically you could call it a relay but it's a fecking big one. Triggering it with a relay reduces the current through the ignition switch and will reduce the chance if burnt terminals. Whether that outweighs the extra complexity... ?
http://jpsc.org.uk/forum/
big_wasa
posted on 13/1/15 at 01:45 PM Reply With Quote
Not counting the initial spike the solenoid draws around 10A.
posted on 13/1/15 at 07:42 PM Reply With Quote
Burnt out ignition switches are fairly common due to the initial heavy current drawn by the solenoid.
