TimC
posted on 31/1/15 at 05:34 PM |
Tips for fitting headlamps to Fury / Cobra / Etc. ?
Hi All,
I cut the holes to fit the headlamps on my Gemini today. Has anyone got any advice on how the bowls etc on the lights should be fitted, in particular
how they are aligned? Is there a specific top, bottom etc.? I'm referring to WIPAC 7" lamps.
Thanks.
TC
posted on 31/1/15 at 07:08 PM |
If you look at the lens there should be a horizontal line with a kick up around 15 degrees on one side , make sure the line ends up being horizontal.
IIRC if you are using a chrome rim there may be a dimple which should be at the top
gremlin1234
posted on 31/1/15 at 07:14 PM |
there should be two adjusters, one for left/right, and one for up/down.
these should (strangely enough) be on the horizontal and vertical axis's
TimC
posted on 31/1/15 at 08:07 PM |
That makes perfect sense.
Many thanks.
