blakep82
posted on 6/3/15 at 05:33 PM |
has anyone fitted dim dip headlights?!
Just having a major panic. I've heard of dimp dip before, but never thought about what it means
I have led side lights (seperate to the headlights. Could wire them as drl?), and 90mm hella headlights, which have a single H7 bulb with a flap to
make them dip.
I never actually knew that dim headlights come on with the first click of the headliggt switch too, since 1987.
Do I need them?! Starting to worry about how that'll work now
[Edited on 6/3/15 by blakep82]
________________________
theduck
posted on 6/3/15 at 05:40 PM |
You need
Sidelights
Dipped headlights
Main beam
I have no idea what dim dipped or dimp dipped are...
Ben_Copeland
posted on 6/3/15 at 06:13 PM |
Not seen it on cars for years.
Just stick with the above ^
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
posted on 6/3/15 at 06:23 PM |
It was a good British idea that the EU didn't like as a result it go binned.
loggyboy
posted on 6/3/15 at 06:40 PM |
The dim dip principle was short lived. My 86 escort had them. as did my 90 nova, but my 92 nova didnt.
When side lights were turned on with ign off, you got regular 5w sides (seperate bulbs), when the ignition was on the dipped head lights would light
about 50% brightness. It just gave a slightly brighter side light.
[Edited on 6-3-15 by loggyboy]
Mistral Motorsport
theduck
posted on 6/3/15 at 09:21 PM |
Ah ok. Good to know.
blakep82
posted on 6/3/15 at 10:06 PM |
Definitely good to know! And a relief too, thank you
So, headlights, 1 relay 2 fuses? Sound like a plan?
CosKev3
posted on 6/3/15 at 11:09 PM |
My '88 cav sri130 had them,pain in the arse when the dim dip relay buggered up and left my headlights permanently on!
Luckily once I removed the relay the lights still worked as normal minus dim dip.
snowy2
posted on 21/3/15 at 07:37 AM |
Dim dip was a weird sort of idea that sounded good on paper but achieved nothing other than to massively increase the costs to the car using them, if
fitted they must work for the MOT and the unit controlling them is VERY expensive. they didn't do much to improve safety other than when the
idiots on motorways in poor lighting or heavy rain who think that side lights make them visible to other road users....a simpler idea would to have
been to make the use of side lights when moving where lights are needed illegal.....
sometimes you are the pigeon, most of the time the statue.
Bluemoon
posted on 21/3/15 at 08:45 AM |
Our 7 Has them, std seria loom....
