Author: Subject: wiring loom
200mph
posted on 17/2/05 at 06:38 PM Reply With Quote
wiring loom
Just after the concenus on whether to use the wiring taken from the donor, or is it worth purchasing a new ready-made jobbie?
opinions appreciated
cheers
Mark
tom_loughlin
posted on 17/2/05 at 06:42 PM Reply With Quote
i think it depends on how electronically minded you are, and how long you have got to strip down the existing loom.
i bought a loom from PWS, but i think if i were doing it all again, id prob start from scratch, as i need all sorts of ecu's etcc.. to get the engine running.
hope this helps,
Tom
Jon Ison
posted on 17/2/05 at 06:46 PM Reply With Quote
i enjoyed making my own, took a couple of days but i was left with system that i fully understood if i ever had to fault find, cost as much as buying a loom mind you, one tip, I like many others used 7 core trailor cable from front to back of car, more than enough for the lights and fuel tank sender.
clbarclay
If you're using looms from older cars like mk2 escorts then the originol loom on its own is not satisfactory.
For instance, if your car needs an electric fan the standard loom will not run it. The same goes for a warning light on the brake lines (SVA requirment).
posted on 17/2/05 at 06:48 PM Reply With Quote
For what its worth I started with the donor Sierra loom, but pretty soon gave up and bought a Vick Green loom from lolocost - IMHO it's not worth bothering with the donor's loom.
HTH
Nick
clbarclay
posted on 17/2/05 at 06:49 PM Reply With Quote
If you buy in a new loom make sure you can use it with indicator stalks, ignithion key, etc.
Other wise these will have to be bought as well.
200mph
posted on 17/2/05 at 07:38 PM Reply With Quote
how labour intensive is making your own? As with most things its probably the same to pay a company, but it is the kinda thing I would enjoy making.
Are there suppliers that come recommended?
cheers for the replies
Mark
Trev Borg
posted on 17/2/05 at 08:04 PM Reply With Quote
I stripped the entire loom out of my alfa.
The bloody thing weighed more than i do.
But once you have got the loom out, and a nice diagram of the thing, you can just go and chop all the bits you want off.
It leaves with too long, and skinny loom.
Throw it somewhere near the front and back of the car, and cut and reconnect the slack in the middle.
If you keep as much of it in the standard colours as possible it always helps if you have any problems.
The one i really don't like is home made looms made from red and black wire only.
If you take your time you can make a nice job of it, and actually get all the bits you want in the right place with there being any spare loop of loom kicking around.
It may be a challenge but there are lots of people on this site can help if you get stuck.
Go for it.
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
indykid
posted on 17/2/05 at 08:45 PM Reply With Quote
Mark
it took me about a month and a half of weekends to figure out what i wanted, strip the old loom and run it all again. it took so long mainly because i attached the horn, rad, tank sender etc as i went including fabbing brackets and what not.for a fuse box panel, i started with hardboard,as it was easy to carve bits out for relays etc, then finally made it in ally
call me sad, but to date i think it has been the most enjoyable and rewarding part of the build
if you plan to do it, assuming it is a sierra donor, the wiring diagram in the haynes (greeny turquoise, old style, real paper)manual was near spot on for all the wire colours. the wiring diagrams are easy to follow too.
just don't lose heart and keep plugging
tom[pg=]
Jon Ison
posted on 17/2/05 at 09:19 PM Reply With Quote
http://www.vehicle-wiring-products.co.uk/
all you could ever need, recomended.
clbarclay
posted on 17/2/05 at 09:22 PM Reply With Quote
Indykid did all your loom come from a 1.6 sierra?
I'm investigating posible electric rad fans and thought that only the 1.8 cvh sierra's had electric fans.
indykid
posted on 17/2/05 at 09:31 PM Reply With Quote
yes all 1.6 loom.
therefore it has no electric fan, but does have a heated rear windscreen,rear wiper motor,central locked rear doors, all with butch wiring, far exceeding the 20a fuse for the rad fan (from CBS/nfauto btw £45 935cfm apparently)
make your initial loom, keep the other bits (read hefty chunk, about 10kg) in a box and scavenge from it as and when, trying to retain colours, useful for miscellaneous earths and stuff
hth
tom
[Edited on 17/2/05 by indykid]
zetec
posted on 17/2/05 at 09:53 PM Reply With Quote
Go for a Premier Wiring loom if you want the easy route. Lots have people have used it and it is very straight forward and everything is correct and fitted with fuses and relay holders.
The company are 110%, very helpful and I've never heard a bad word said about them.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Snuggs
posted on 17/2/05 at 10:00 PM Reply With Quote
The £45 fan from CBS is excellant value.
I run 2 on a RV8 and have no overheating problems.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
clbarclay
posted on 17/2/05 at 10:04 PM Reply With Quote
Does the fan include an auto on/off control, or is the fan perminantly on.
clbarclay
posted on 17/2/05 at 10:06 PM Reply With Quote
Why can't this forum allow me to edit a post when i told it to post too hastaly.
I mean the CBS fan
flak monkey
posted on 17/2/05 at 10:08 PM Reply With Quote
You can edit...just click the little edit button up in the right hand corner of your post....i do it all the time as i type too fast and then (buttons about ^^^ here) dont read what i typed....
[Edited on 17/2/05 by flak monkey]
Sera
http://www.motosera.com
indykid
posted on 17/2/05 at 11:11 PM Reply With Quote
no, the fan is just a fan, 2 wires.
i'm running it with an mk rad tho, so has a hole for a fan switch. i used a cavalier one as i know they run unrelayed, and a 25a toggle switch for a manual override.
hth
tom
posted on 18/2/05 at 12:55 AM Reply With Quote
I spliced a BE loom and a Sierra loom together - most of the loom from the bike did the job - used the Sierra loom to add bits in etc. Hazards and Fog I made up my own from trailer wire. I'm no whizz when it comes to wiring but as long as it is safe (came from bike or car) then by default I assume it's safe to use on a se7en. I must have enjoyed it as I'm doing it again on the ZX12R... which is much worse than any bike loom I've ever seen
indykid
posted on 18/2/05 at 12:57 AM Reply With Quote
tee hee, aint it the best
tom
mookaloid
posted on 18/2/05 at 09:51 AM Reply With Quote
Premier Wiring is by far the easiest and neatest way to go. Cost about £95 and all the support you need.
Mark
posted on 18/2/05 at 12:50 PM Reply With Quote
I made my own loom using coloured wires according to the british standard. Because I had some waste I probably spent as much as if I'd bought the premier wiring loom, but had a lot of fun designing it, and the loom may not have met my perculiar requirements (ooer!).
There is a cheaper option - use just a few colours, and use easily available cable markers to identify each one. There is a huge saving to be made when you buy whole reels of cable, and there's a lot less waste. If I ever wire another car then this would be the way I'd go.
cheers,
posted on 18/2/05 at 02:07 PM Reply With Quote
cheers,
I was thinking along the very same lines - however, when splicing between bike and car - the brown and it's related wires on the sierra is earth. On a bike earth is green. I was considering stripping the lot , but as the ECU from the bike contains about 40 wires - I thought better of that....
How much are reels of cable suitable for this? I may still buy 5 or so to get me by...
