lexi
posted on 20/4/05 at 09:07 PM |
headlights
Hi guys
A while back I bought a pair of brand new spots for my Patrol. Went to fit them the other day and realised they are actually headlights.
They are Bosch and are MOD. without bulbs. Glass is marked H4. Do you think they would be suited to Locost?
Lexi
posted on 20/4/05 at 09:47 PM |
Sounds like they should. H4 is the bulb type I should think.
lexi
posted on 21/4/05 at 05:18 PM |
Thanks Pete
Had a closer look at them today and they are adjustable inside and have E4 with a circle on the glass. Also HCR and 12rt. Anyone
know what this all means and will they be SVA ok?
Cheers Alex
Steve @ sVc
posted on 3/5/05 at 12:38 PM |
The "E" mark shows it has been passed to comply with European specifications - the number refers to the country where it was originally
tested.
HCR stands for Halogen - Dip and Main beam.
For driving in the UK, your headlights should dip to the left - away from on-coming traffic. Your lens will have an arrow pointing to the left when
looking from behind the light to show it does this, or in some rare cases an arrow pointing to the left and right if it is adjustable for UK and
Continental driving.
If there is no arrow it either dips vertically down (motor cycle) or to the right for the Continent. If so you will most likely fail SVA and Mot.
You may have other numbers referring to the type approval cert. number.
12 is the luminous intensity number (not very high) it goes up to 37.5, lowest number is 10.
Regards
Steve @ sVc
