rayroni
posted on 5/5/05 at 01:46 PM |
Wiring rear lights & SVA compliance
Do off side and near side rear lights (inc. parking lights) have to be run off separate fuses, or will SVA be satisfied by them ‘running’ through a
single fuse?
Is there any other ‘major’ reason not to run them through a single fuse?
Mike S
posted on 5/5/05 at 02:39 PM |
Don't think its an issue with SVA as long as they work. But IMHO it makes good sense to have them separate as if you blow one circuit, at least
you still have one light at the back. If you run from a single fuse you would not have any!!
Mike
posted on 5/5/05 at 02:43 PM |
I use 2 fuses: one for the left rear and left front sidelights, the other for the right rear and front.
As Mike says, it's nice to keep one light showing if a fuse blows, at the front AND the rear!
rgds,
craig1410
posted on 5/5/05 at 10:23 PM |
Same here, I have split my circuits left from right. It is not difficult as your fusebox will most likely be somewhere near the engine bulkhead or
just in front of the gearlever so it is very natural to run one cable forwards and another backwards, driven from separate fuses with a common
input.
Craig.
