Author: Subject: Low brake fluid sensor
jonbeedle
posted on 19/7/05 at 01:06 AM Reply With Quote
I have a Sierra master cylinder on top of which there is a low brake fluid warning thing on the screw cap. It has three wires on it. On my Premier Wiring loom I have one wire that needs to be connected to this. I can't figure out which wires go where. The instructions I got with the loom aren't that clear to me. Anyone have any ideas?
I could 'phone Premier Wiring but I work nights and I might not be up in time tomorrow to catch them before the close of business. Anyway it's easier to post the question on here!
Jon
"Everyone is entitled to an opinion however stupid!"
posted on 19/7/05 at 07:10 AM Reply With Quote
I can't remeber the exact layout, but one wire goes to earth, and the remaining 2 go to the warning light - they both work together. I guess that they did different jobs in the Sierra...
A couple of minutes with a test meter or bulb & battery will soon tell you which is which.
Jeffers_S13
posted on 19/7/05 at 07:11 AM Reply With Quote
One goes to handbrake switch I think.
DarrenW
posted on 19/7/05 at 08:16 AM Reply With Quote
iirc you use the outside two wires from the std Sierra bottle cap. One is earth, the other is the warning level switch wire. Cant remember the colours off hand - i think one is brown = earth.
James
posted on 19/7/05 at 09:43 AM Reply With Quote
Agree with Darren there- the Premier instructions say ignore the middle one.
Then one to earth and the other to the loom.
HTH,
James
posted on 19/7/05 at 09:46 AM Reply With Quote
Brown to earth, brown/green to handbrake switch, brown/yellow to dash warning light.
DarrenW
posted on 19/7/05 at 10:50 AM Reply With Quote
Premier loom doesnt require the middle wire. Seperate wire from Handbrake switch can be set up.
Why does the middle wire go to the handbrake switch - is it cos they share the same dash light on the sierra??
posted on 19/7/05 at 11:09 AM Reply With Quote
Yes.
Dusty
posted on 19/7/05 at 02:35 PM Reply With Quote
Its ignition live to bulb, then on from there to the middle or left contact on the sensor (they are common). The unused common then runs to the handbrake switch and on to earth. The right contact runs to earth. The idea is that the handbrake switch can then function as the low fluid sensor light tester.
posted on 19/7/05 at 02:41 PM Reply With Quote
...and the handbrake connection tests the entire wiring circuit up to the switch, in case there's a break.
posted on 19/7/05 at 06:18 PM Reply With Quote
they (as in ford!) could've wired it with two wires leaving the bulb, one to the handbrake and one to the fluid level sensor, but as pointed out, that wouldnt necessarily make the hanbrake switch test the full circuit. Hence it goes to the fluid level sensor first, and then doubles back to the handbrake, giving two alternate earths in total.
[Edited on 19/7/05 by JoelP]
Avoneer
posted on 19/7/05 at 06:41 PM Reply With Quote
It's the two connectors on either side - igore the middle one.
One to earth, the other to the "tell tale" - don't bother taking it all the way back to the handbrake connector as you can connect it to the other end of the wire that goes to the handbrake where it connect to the tell tale under the dash.
Easy.
Pat...
