Author: Subject: Wiring diagram
jonbeedle
posted on 19/7/05 at 03:50 PM Reply With Quote
Wiring diagram
I'm sure this has been asked before but has anyone put together a wiring diagram for a 'book' Locost, preferably with a xflow engine? I'm sure I've seen it on here but can't find it.
I have a Premier Wiring loom and I'm having difficulty with the engine spur as the instructions are basic. I can't get through on the helpline. I've wired the rest of the car I'm just stuck on this bit. Any help would be appreciated.
Jon
[Edited on 25/7/05 by jonbeedle]
"Everyone is entitled to an opinion however stupid!"
Deckman001
posted on 19/7/05 at 04:06 PM Reply With Quote
which part are you stuck on, I've just wired my premier loom to me x/flow
Jason
jonbeedle
posted on 19/7/05 at 05:22 PM Reply With Quote
The green tacho impulse wire
The blue charge light wire, not sure where these go. I think I need an ignition amplifier as well what ever that is, therefore I think the black wire that I've connected to the coil +ve should go through the amplifier too.
Jon
Deckman001
posted on 19/7/05 at 06:15 PM Reply With Quote
You'll get a u2u soon, once i check the motor
Jason
DavidM
posted on 19/7/05 at 09:44 PM Reply With Quote
Hi Jon,
If your using the standard Xflow ignition then the black wire goes to coil +ve and you don't need an ignition amplifier. If your using electronic ignition I've no idea.
The blue charge light wire goes to the alternator 3 pin plug along with the two red wires.
Don't know about the tacho impulse as I've not fitted one.
Proportion is Everything
jonbeedle
posted on 20/7/05 at 12:27 AM Reply With Quote
Thanks chaps.
jos
posted on 20/7/05 at 07:57 AM Reply With Quote
Jon
Just to let you that I'm keeping an eye on your posts re Premier wiring looms and am sort of in the same boat as you so all of your posts and subsequent replies are extreemly useful for me
johnjulie
posted on 24/7/05 at 05:29 PM Reply With Quote
The green wire from the Tacho goes to a fuse that is live when the ignition is on. The wire from the alternator goes to the ignition bulb. The other side of the bulb needs to be live with the ignition on!
Cheers John
posted on 24/7/05 at 10:34 PM Reply With Quote
Goes to the distributor terminal on the coil doesn't it?
Marcus
posted on 25/7/05 at 05:43 PM Reply With Quote
I'm with Pete on this one, green wire to coil -ve. The +ve coil starts black, then goes white or beige - ballast resistor.
Blue wire goes from alternator plug (smallest terminal) to charge light on dash.
Marcus
Marcus
Because kits are for girls!!
