Author: Subject: BLADE LOOM CONNECTION TO IGNITION
GeoffB
posted on 26/7/05 at 09:32 PM Reply With Quote
I HAVE BEEN USING DODGY ROGERS INSTRUCTION TO CONNECT THE BLADE WIRES TO THE SIERRA IGNITON SWITCH IT SAYS
THE FIREBLADE BLACK/WHITE IGNITION WIRE CONNECTS TO THE BLACK WIRE FROM THE SIERRA SWITCH
THE FIREBLADE YELLOW/RED WIRE CONNECTS TO THE GREEN/ BLACK WIRE FROM THE SIERRA IGNITION SWITCH
I DONT HAVE ANY OF THESE WIRE FROM MY SWITCH..I HAVE
BLACK/BLUE
BLACK YELLOW
YELLOW
RED
ANY IDEAS..?
Avoneer
posted on 26/7/05 at 09:50 PM Reply With Quote
No, sorry - but no need to shout!
Pat...
GeoffB
posted on 26/7/05 at 11:04 PM Reply With Quote
SORRY..must type with caps off
ps question still stands
chrisf
posted on 27/7/05 at 02:47 AM Reply With Quote
I suspect you have a different year blade engine than the Dodgy Roger. What year is your engine?? A 98-99??
--Chris
GeoffB
posted on 27/7/05 at 07:13 AM Reply With Quote
ITS A 97 BLADE ENGINE , I PRESUMED THE PROBLEM WAS THE SIERRA INGNITION WIRES WERE A DIFFERENT COLOUR.. MINE DONOR WAS AN 'E-REG' 1987/88
posted on 27/7/05 at 10:21 AM Reply With Quote
BLACK/BLUE To Sierra solenoid
BLACK YELLOW Switched live ignition on
YELLOW Accesories, radio.
RED Permanent live
Caps lock is on the left .
GeoffB
posted on 27/7/05 at 12:03 PM Reply With Quote
thanks for the info..but i still need to know
what are the two colours on the switch that dodgy rodger is referring to on the sierra ignition i.e
black wire on sierra switch
green/black wire on sierra switch
chrisf
posted on 27/7/05 at 01:18 PM Reply With Quote
So are you confused about the wiring on the Sierra switch or your fireblade loom? Have you seen the other wiring diagrams out there? Shortie, for one, has a good wiring diagram.
--Chris
GeoffB
posted on 27/7/05 at 01:34 PM Reply With Quote
THE COLOURS ON THE FIREBLADE LOOM ARE THE SAME AS MINE .. ITS THE COLOURS COMING FROM THE SIERRA IGNITION SWITCH THAT ARE DIFFERENT..
HE CONNECTS TO A BLACK WIRE ON THE SIERRA IGNITION SWITCH
HE CONNECTS TO A GREEN/ BLACK WIRE ON THE IGNITION SWITCH WHICH I CANNOT FIND ANY REFERENCE TO ON ANY DIAGRAMS
OR TO PUT IT ANOTHER WAY......
DOES ANYBODY KNOW WHERE THESE GO
A 97 BLADE ENGINE..TO A SIERRA IGNITION SWITCH USING THESE COLOURS THAT ARE ON MY SWITCH
BLACK/BLUE
BLACK YELLOW
YELLOW
RED
BLACK/WHITE IGNITION WIRE FROM THE BLADE LOOM
YELLOW/RED WIRE FROM THE BLADE LOOM
mookaloid
posted on 27/7/05 at 01:47 PM Reply With Quote
I see you're back to shouting
Mind you I'm not suprised I thought your question was clear in your first post
I would give Roger another try
Mark
[Edited on 27/7/05 by mookaloid]
posted on 27/7/05 at 01:49 PM Reply With Quote
IF YOU DON'T HAVE THEM WHY DO YOU WANT TO KNOW WHAT THEY DO? ALL YOU NEED TO KNOW IS WHAT THE RED/YELLOW DOES ON THE FIREBLADE AND CONNECT IT TO THE APPROPRIATE WIRE ON THE SWITCH. IF IT FIRES THE RELAY IT GOES TO THE BLACK BLUE. IF IT RUNS IGNITION DEPENDENT CIRCUITS IT CONNECTS TO BLACK/YELLOW ETC. Knock the caps off again it's sending my eyes funny
