Author: Subject: Smallest Headlight (w/Sidelight?) ?
Kissy
posted on 16/10/05 at 07:24 PM Reply With Quote
Title says it all - what is the smallest headlight (Main/Dip) I can get, ideally with a sidelight built in, that will pass an MOT? Ta.
Deckman001
posted on 16/10/05 at 07:35 PM Reply With Quote
I'm using the small Gts ones, they are apparently now sva friendly ( the beams pointing the right way) but I havn't got to sva yet so can't confirm
http://www.gtscougar.freeserve.co.uk/headlamp2.jpg
Jason
lsdweb
posted on 16/10/05 at 07:38 PM Reply With Quote
You could try some of the motorcycle units - I've got a pair on my car but it's pre SVA - they have a built in main beam warning lamp too!
Regards
Wyn
posted on 17/10/05 at 11:50 AM Reply With Quote
I believe MOT is not as stringent as SVA when it comes to headlights. SVA will want to see correct beam pattern and conformity markings whereas MOT doesn't check these IIRC.
Probably doesn't answer your question but will have a bearing if your vehicle isn't SVA'd yet.
