Author: Subject: Problems with blade clocks
esn163
posted on 20/3/06 at 03:46 PM Reply With Quote
Hi again,
We are still having problems with the blade clocks from this thread. I have checked all wiring but cannot find a fault anywhere. What displays on these clocks with just the ignition on? They worked when we tested them on the bike but I can't remember what is displayed before the engine is started so not sure whether this is normal or not.
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
mike smith1
posted on 20/3/06 at 03:56 PM Reply With Quote
As far as i remeber its neutral light, oil pressure light, temp shows as - - then oC,
and mileage. will check later and confirm for you.
I am talking about clocks from a 98 blade
Cheers Mike
chrisf
posted on 20/3/06 at 06:00 PM Reply With Quote
I had the same problem. I'm doing this from memory, so bear with me...
IIRC, there are three wires from the clocks that must be grounded/earthed. It was ambiguous is the factory diagram. Once sorted, the issue goes away. If I remember right, it was my tach gauge that didn't work...
Anyway, I can look tonight to see what wires need to be grounded. Hopefully someone will answer sooner.
--Chris
esn163
posted on 22/3/06 at 03:54 PM Reply With Quote
Thanks guys for the replies, must be something wrong somewhere as the displays are blank so the search for the problem continues. Going to check the earth connections again. Will let you know how I get on.
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
esn163
posted on 25/3/06 at 08:09 PM Reply With Quote
Fixed it I missed earth connection between the speed sensor supply and the clocks out.
Ed
[Edited on 25/3/06 by esn163]
Indy Build Photos
** Build pages **
Photo Bucket Pics
