Author: Subject: Electric heater valve?
RazMan
posted on 5/4/06 at 08:22 PM Reply With Quote
I want to have a switch on the dash to open an electrically operated valve to the heater matrix flow. Does anyone know of a suitable one?
Raz
Jon Ison
posted on 5/4/06 at 08:44 PM Reply With Quote
Would the electrical one that opens the accusump do the job, not seen one but it operates on 12v and I would guess is 1/2" bsp fittings, could you run into probs with air locks in system ?
RazMan
posted on 5/4/06 at 08:53 PM Reply With Quote
Yep, that looks ideal for the job - except for the price - $100
I shouldn't have any airlock probs if it is bled properly although time will tell
Raz
Jon Ison
posted on 5/4/06 at 08:56 PM Reply With Quote
how about a cheap manually operated ball valve under dash, that's what i used on the accusump........ ?
RazMan
posted on 5/4/06 at 09:05 PM Reply With Quote
CBS do quite a nice plastic one which I could mount in the side of the tunnel next to my battery cutoff switch.
I would rather have a switch if possible though
Raz
mark chandler
posted on 5/4/06 at 09:37 PM Reply With Quote
Vacumn watervalve from a jag, loads of 12v options for switching air or gas (LPG solinoide maybe)
j_davis
posted on 5/4/06 at 09:40 PM Reply With Quote
If you shut off the supply to the heater, usually it is best to bypass it to maintain the flow path.
While searching in the scrapyard I found that sierras and granadas with air con have such a valve (it looks like a mushroom). It is operated by manifold vacuum, and there is a nice electric solenoid valve in the vacuum pipework.
So with a flick of the switch on my dash the flow either goes through the heater or bypasses it and returns to the pump.
HTH
jock
posted on 5/4/06 at 09:44 PM Reply With Quote
valve
a mk 4 fiesta has elec heater valve and it buypases when shut
j_davis
posted on 5/4/06 at 10:05 PM Reply With Quote
Just found this on ebay
Here
RazMan
posted on 5/4/06 at 10:14 PM Reply With Quote
Triffic ideas there guys - thanks to everyone.
The Ford valve would seem to be the best solution as it will bypass the heater matrix but still retain the flow (as has been suggested) and reduce the chance of airlocks.
I will see how the auction goes and have a snipe at it
Raz
RazMan
posted on 5/4/06 at 10:39 PM Reply With Quote
I just found a 'buy it now' Fiesta/ Transit valve for £15 so I snapped it up! Not sure why it needs 4 connections yet but I guess I'll sort it out when it arrives.
Once again, thanks for all the input.
Raz
JonBowden
posted on 6/4/06 at 08:27 AM Reply With Quote
Central heating systems use electrical valves - don't know if any are 12V though
Jon
posted on 6/4/06 at 09:44 AM Reply With Quote
needs 4 connections because of the by-pass
Heater flow -- engine flow
heater return, -- engine return
