Author: Subject: switch ratings....
Viper
posted on 27/5/06 at 01:48 PM Reply With Quote
switch ratings....
can any one help????
what amperage does a fog light switch need to be able to handle? and what if it went through a relay?
also what amperage switch for ignition "on" (so to speak) if switched through a relay???
any ideas chaps?
cheers......
Howlor
posted on 27/5/06 at 02:16 PM Reply With Quote
Well i think a fog light is about 21W so if you are going to fit two then 42W, P=IV so 42/12=3.5A.
With a relay it can be very little.
Viper
posted on 27/5/06 at 02:27 PM Reply With Quote
I am only itting one fog light, those numbers you posted look a lot like math to me and my little brain don't do math.....
so only one fog light (21w) the switch would need to have a minimum rating of?
Howlor
posted on 27/5/06 at 02:54 PM Reply With Quote
It then would be 21W/12V = 1.75A. I am uncertain for an ignition switch but I would reckon on about 25A.
hope that helps,
ady8077
posted on 27/5/06 at 04:36 PM Reply With Quote
Hi
If your looking for switches from maplins/ rs etc, make sure the amp rating is for a DC voltage
Adrian
Viper
posted on 27/5/06 at 04:48 PM Reply With Quote
all a bit to complicated for me....
so is there any way of working out what i would need if it is advertised as a AC switch?
BKLOCO
posted on 27/5/06 at 06:27 PM Reply With Quote
No not really.
The problem is that DC draws an arc as the contacts break whereas AC doesn't.
Therefore different contact material tends to be used for the two switches.
As a general rule of thumb however if the ac rating is in the order of 4 to 6 times what you intend to switch dc you should be ok.
[Edited on 27-5-06 by BKLOCO]
