Author: Subject: points distributor
jabbahutt
posted on 11/10/06 at 06:05 PM Reply With Quote
points distributor
Hello
just starting wire up my engine bay, hope someone can help
2.0 pinto with points based dizzy and non ballast coil, I have a thin fly lead which comes from the dizzy, should it go to the +'ve or -'ve
thanks
posted on 11/10/06 at 06:18 PM Reply With Quote
Lead should go to the coil neg - terminal Pos feed via ignition switch to the +terminal
Dusty
posted on 11/10/06 at 11:55 PM Reply With Quote
Also need a lead from neg terminal of dizzyto the rev counter if you have one.
[Edited on 11/10/06 by Dusty]
posted on 12/10/06 at 08:35 AM Reply With Quote
usually the coil has a double male spades on each terminal; your rpm counter would got there (electrically the same but physically different).
If you don;t have the doulbe spade, either make one from copper tube or buy them from VWP - cheap as chips but for the postage.
Dusty
posted on 14/10/06 at 12:34 PM Reply With Quote
Whoops. Meant coil not dizzy although it is two ends of the same wire but had a brain hiccup.
