jon_boy
posted on 12/11/06 at 01:38 PM |
mk6escort key barrel wire colours
Which colour is ignition and which colour is starter from behind the key barrel. Choices are Red Black Yellow and blck with a blue stripe. Jon
jon_boy
posted on 12/11/06 at 01:53 PM |
And with a multimeter or even a circuit tester that would be the answer but with my dash out and alarm half in i cant go buy one and the wires i
assumed were the ones are not. see my problem
stevebubs
posted on 12/11/06 at 02:54 PM |
From my fitting notes....
Feed = Red
Pos 2 = Black
Pos 1 = Yellow
Start = Blue/Black
[Edited on 12/11/06 by stevebubs]
stevebubs
posted on 12/11/06 at 02:56 PM |
And if you're going to wire up the stalks...
Fiesta Switch Gear
Left
H (71?) - Horn Relay (+=on) (Red/Yellow)
49/15 - Live (Ignition) (black/brown)
31 - Ground (Brown)
R - To Right Indicators (Pulsing +=On,) (black/green)
L - To Left Indicators (Pulsing +=On,) (black/white)
30 - Live (Permanent) (red) (for Hazards, Sidelights)
58 - Sidelights (+=on), Tail lights , Fog Safety (grey)
55 - Foglight Enable (white/black) (+=on)
56B - Dipped (yellow) (+=on)
56A - Beam (white) (+=on)
54 - Live (ignition) (black/violet)
53B - Front Wiper Motor Fast (Red) (on=12v; off=float)
53 - Front Wiper Motor Slow (Green) (on=12v; off=float)
53A - Rear Wash/wipe (Black) (12v=on; earthed when off)
53-2 - Front Wiper intermittent Relay (Black/Green)
B2 - Front Wiper Intermittent Relay (Brown / Yellow) Signal power (12v=intermittent on)
Front Washers
W - Front Washers (Black / Blue) (Permanent Live)
53C - Front Washer (Black) (switched earth)
B1 - Front Wiper Motor Intermittent Relay (Brown / White)
Who gives a monkey about the rear?
jon_boy
posted on 12/11/06 at 05:11 PM |
Many thanks. Like i say its for an alarm im trying to wire. Cut my losses tonight and took out what id done but maybe tomorrow. Cheers again.
posted on 12/11/06 at 05:28 PM |
Get one of those screwdrivers with a light in the handle and a wire with a crocodile clip while you're at it. They are invaluable for poking
round and finding what's live when the switch is in different positions and you can undo screws with them
jon_boy
posted on 12/11/06 at 11:59 PM |
Hmm, got the alarm kind of working. Is it normal for what was earth to switch to live once the car is running? and thats before i got to it!
