myeates
posted on 26/12/06 at 01:18 PM |
water temp warning light
hi all
i am goin to put a water temp warning light in the car as well as a guage. the engine is the 1.3 x-flow with the guage pick up already on (well i
thing it is) and i will also need a separate thermostat switch for the fan can either of these be used for powering the light, if so any idea how as
dont really want the light coming on all the time when fan comes on
thanks guys
Danozeman
posted on 26/12/06 at 06:11 PM |
Im wiring a light up through the fan switch relay so i know when the fans in as i cant here it above the engine. Its a bit complicated i think to
have a high temp light wired some other way.
Dan
Chippy
posted on 26/12/06 at 10:33 PM |
You can, I think, get a tee piece that screws into the block where the existing warning light senser goes. Then mount the gauge on one side, and the
warning light senser on the other. HTH Ray.
John Bonnett
posted on 29/12/06 at 12:19 PM |
I've used a T piece too, one arm for the gauge sender and one for the water temperature sensor. To wire the light, take a feed through the
ignition switch to the light and the other connection from the light to the temperature sensor.
John
