Author: Subject: Fuel cut-off inertia switch
John Bonnett
posted on 29/12/06 at 09:53 AM Reply With Quote
Good Morning All
I have just bought a Ford inertia switch. I would appreciate some help in mounting it.
First question which way up? It has a red button at one end and two horizontal sleeved mounting points above the red button and one at the lower diagonal corner.
Second question There are 3 electrical contacts. Can you tell me what goes where(pardon the bad english)
Any help and advice will be gratefully received. Thank you
John
theconrodkid
posted on 29/12/06 at 10:58 AM Reply With Quote
just mount it somewhere near the front of the car and the button so you can get to it,normally top.
mine has 2 wires on it,got a multi-meter?check out what terms are connected when button is down,give it a smack to pop button up and there should be no con
who cares who wins
pass the pork pies
John Bonnett
posted on 29/12/06 at 05:17 PM Reply With Quote
Many thanks for your reply. I should be ok with the wiring it was the orientation that I needed clarifying and you have done that and I am really grateful.
Thank you again
John
