RichardK
posted on 5/1/07 at 04:42 PM |
Megajolt Farnell Components List
Had a bit of trouble getting the correct parts together after ordering my board, box and chip from the states.
Have got a part list together to use at Farnell online, everything we should need except the female crimped connectors which you can source by getting
L70AZ from Maplins which will give you the connectors you need as well as a block you won't need, but it's still cheaper doing it this way
as Farnell only sell the connectors in 500's for about £13!
I haven't built mine yet but if anybody spots an error can they let me know and I'll correct it, obviously it's down to you to check
yourself that these are the correct parts and I won't be held accountable for any damage that using these bits may cause. But saying that I
reckon I'll find out before you if things go wrong
Rich
Apparently this fella martin@millener.com can get all of the stuff but a bit cheaper, too late for me but somebody can give him a try.
[Edited on 5/1/07 by RichardK]
Gallery updated 11/01/2011
paulf
posted on 5/1/07 at 04:59 PM |
All those parts look good to me , but you have added an 18v zener that is not required?
Paul.
PeterW
posted on 5/1/07 at 05:01 PM |
Rich
Rich
TPS or MAP...??
Peter
RichardK
posted on 5/1/07 at 05:21 PM |
Good point, TPS
But if somebody fancies doing a MAP version that would be excellent
Rich
RichardK
posted on 5/1/07 at 05:22 PM |
Paul.
Forgot to say that the order came £19.87 ish so added them on to get it over £20.00 so I could order with my cc
I thought I would need an 18v zener to get my tacho working. Getting ready to be corrected!
