Author: Subject: finding what wire from where
bracey
posted on 7/1/07 at 05:51 PM Reply With Quote
hi guys ,in process of wiring new dials into dash board ,is there a way to find out which wire from what or is it justa case of trial and error ,seems more error at moment
cheers
richard
jollygreengiant
posted on 7/1/07 at 06:02 PM Reply With Quote
when in doubt - - - - multimeter.
RazMan
posted on 7/1/07 at 06:03 PM Reply With Quote
Use a test lamp connected to a 9v battery - no damage when you short something out
Raz
bracey
posted on 7/1/07 at 07:02 PM Reply With Quote
mainley trying to find dash lamp power instructions say one wire to chassis other to dash lamp power ,i have had lights on when turning ignition on but not when turning lights on ?the chassis wire is deffinately right as can trace to bolting point on chassis ? i also need neg side of coil for tacho is there best way to find ?
davidwag
posted on 7/1/07 at 08:34 PM Reply With Quote
If you cant be sure which wire goes to coil then easest to run your own wire direct.
David wag
