davrus
posted on 5/5/07 at 10:36 AM |
Electric speedo setting
Hi again
Can any one tell me what figure to put in to my speedo in order for it to read correct.
I have an acewell speedo with 1 pick up sensor mounted in the rear brake drum.
My tyres are 185 70 13
Hope you can help
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
flak monkey
posted on 5/5/07 at 10:40 AM |
Your theoretical circumference is 1851mm, so use that to start with.
After that the only way to check its right is at the sva test, or follow another car at a known speed.
See:
http://www.carbibles.com/tyre_bible.html
Just over half way down there is a calculator for circumference.
Sera
http://www.motosera.com
Fatgadget
posted on 5/5/07 at 12:21 PM |
Or calibrate it using the marker posts on any motorway. I believe they are a set distance apart.Can't remember the exact figure.
Marlon
posted on 5/5/07 at 03:48 PM |
I used a tom tom sat-nav to check mine on a very short run, twas perfect at sva.
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
