pointy
posted on 22/6/07 at 08:55 PM |
fast indicators
My indicators are flashing very fast.
Background..
Relay melted.
Relay that melted has/had 2 spade outlets and I cant read the voltage.
Tried 12V 21amp relay with 3 spades
1 is live in 1 is live to switch 3rd 1 is earth.but they flash fast..
Help....
andy p
jos
posted on 22/6/07 at 09:03 PM |
check all of the bulb wattages
when i fitted bike front indicators mine flashed at twice the required speed & i had to find different wattage bulbs to get the to flash at the
required rate
nitram38
posted on 22/6/07 at 09:14 PM |
Did they ever work properly?
Are you sure that it was a relay with only 2 spades?
Is it just a round silver unit with 2 spades at right angles to each other?
If it is, it is a hotwire flasher unit.
Some are for indicators and others for hazards. Some are for indicators plus one repeater. If you use the wrong wattage unit or incorrect wattage
lamps then it will flash fast. This is to let you know that one of your lamps has blown when the correct unit is used.
If the original was 2 pin, maybe you should simply replace it with another 2 pin to keep things simple!
[Edited on 22/6/2007 by nitram38]
RazMan
posted on 23/6/07 at 11:43 AM |
You mention a 21 Amp relay? You should be using a 12V flasher unit capable of handling 50 Watts (2 x 21W + 5W repeater)
As already said, check your wattages are correct as this is normally the reason for fast flashing.
Raz
pointy
posted on 23/6/07 at 04:23 PM |
All sorted
Thanks to you all.
3w motor cycle bulbs in front indicators.
changed to 21 w and all is ok
