Author: Subject: MJ bits - did I get the right bits ?
mcerd1
posted on 19/9/07 at 08:40 AM Reply With Quote
the coil came from an N reg escort (CVH) and the rest from a K reg escort (HCS)
if they are right - what are these bits ?
this was on the EDIS bracket
this was on the coil braket on the N reg car (no EDIS) and next to the EDIS on the K reg car - its connected #2 on the coil (+12v) and appears to earth on the other side
what is it ?
do I need it ?
posted on 19/9/07 at 09:16 AM Reply With Quote
Looks like you did pretty well - the first picture shows everything I used for my Megajolt - EDIS, VR sensor and coil.
Glad to see that you got all the connectors, together with lots of cable attached.
Don't recognise the other odds and ends - probably not important!
mcerd1
posted on 19/9/07 at 09:27 AM Reply With Quote
it took a while, but I managed to get the whole loom, without cutting any of the wires I need (only cut off the bits I don't need - like the ECU )
posted on 19/9/07 at 09:32 AM Reply With Quote
top photo looks like you have all the bits.
middle photo - duno but could it be ballast resistor?
bracket looks like the coil pack sits on top, don't know what the plug thing on the side is.
mcerd1
posted on 19/9/07 at 09:58 AM Reply With Quote
just to make things a little clearer....
the last pic is of the coil bracket, but its the thing on it I'm asking about - if you look in the 1st photo you can see its on the +12V side of the coil (in the HCS loom)
I thought maybe some kind of surge protector/ arrester ? but really I don't have a clue
mcerd1
posted on 19/9/07 at 01:00 PM Reply With Quote
That makes sence - thanks for that
nitram38
posted on 19/9/07 at 01:34 PM Reply With Quote
The ballast resistor is for use on 10V coils.
If you use a 12v coil you can do away with this.
Normally the ballast resister is bypassed during starting so that your 10v coil gets 12v across it. This temporarily boosts your spark at start up.
It is a common cause of problems where the ballast is knackered and the car tries to start then cuts out when you release the ign key.
Don't run a 10V coil without a ballast resistor though as it will fry!
[Edited on 19/9/2007 by nitram38]
mcerd1
posted on 19/9/07 at 02:23 PM Reply With Quote
I had a ballast resistor on my Mk1 fiesta (1979) 9V normal, 12V starting - but I didn't think any of the electronic ignition cars would still use them :?
the resister didn't appear to be wired to anything I'm using (directly anyway)
but my coil is from a later car (I don't think it had a resister) so hopefuly its ok
posted on 19/9/07 at 03:55 PM Reply With Quote
It's not a coil it's a coil pack, 4 coils in a block more like separate bike coils than the old car coil. It's looks like a suppressor.
NeilP
posted on 19/9/07 at 05:43 PM Reply With Quote
Last picture is called a filter and you do need it to get a nice clean spark off the coil pack IIRC (clears volts between spark cycles). Mine has one and you notice a differenceif disconnected...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
paulf
posted on 19/9/07 at 07:46 PM Reply With Quote
The long resistor is probably for a dim dip system or similiar , it is not connected to the ignition circuit I have seen lots of them on fords that I have removed parts from.
The component on the coil bracket is a suppresion capacitor and can be connected to the 12v supply to the coil centre and edis supply.I have never found it to make any difference but as you have it you may as well fit it.
Paul.
mcerd1
posted on 20/9/07 at 09:03 AM Reply With Quote
Thanks all
I was going to fit the filter/ capacitor anyway - but I feel better knowing what it is instead of guessing
