Author: Subject: Starter Relay
Mole
posted on 22/10/07 at 08:32 PM Reply With Quote
Starter Relay
I'm fairly sure I know the answer to this but does the starter relay need a diode in reverse bias. I assume that there is nothing to sensitive to damage.
big_wasa
posted on 22/10/07 at 10:19 PM Reply With Quote
You dont even need a relay.
the solenoid on the starter will draw around 9~10 amps which a standard sierra ignition switch or the likes can easilly handle.
Mole
posted on 22/10/07 at 10:23 PM Reply With Quote
That would certainally make the wiring a little easier.
