Author: Subject: injection distributor
dblissett
posted on 23/9/03 at 09:28 PM Reply With Quote
i have taken a 2ltr pinto out of a grandad injection
the distributor is a bosch one it doesent seem to have any mechanical advance in the distributor
did the ecu sort out the ignition timing
i will be fitting twin 40S
and so do i need another distributor
theconrodkid
posted on 23/9/03 at 09:33 PM Reply With Quote
yup ecu controlled,need carb type dizzy n amp
who cares who wins
pass the pork pies
dblissett
posted on 23/9/03 at 09:37 PM Reply With Quote
thanks
any ones to look out for and will i need the coil and the amp from one car or can i use my old ones
Dusty
posted on 24/9/03 at 10:27 AM Reply With Quote
6 wire inductive discharge unit is easiest from a pre 85 carbed 2.0L or 1.6 with the matching Bosch dizzy with vacuum and mechanical advance. You don't get to use the vacuum advance if you're running twin 40's but you can tune the mechanical advance to good effect.
dblissett
posted on 28/9/03 at 08:21 PM Reply With Quote
thanks
thanks for the help its of to the scrap yard for me then
