Author: Subject: testing speedo sensor
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
Building: Built haldane 100, retirement project Marcos GT
posted on 31/12/07 at 12:19 PM Reply With Quote
hi, my electronic speedo stopped working a while back, just went haywire and then nothing, at the speedo itself i've got power/earth/dash light and sensor wire going in, all ok except sensor wire, question is how do i test that wire? been told a circuit test wont do it.
posted on 31/12/07 at 01:39 PM Reply With Quote
I'd suspect the sensor and it's wiring then
You can check for continuity between the sensor signal and where that wire attaches to the dial. The only real way of testing for a signal is with an oscilloscope. The speedo sensors often have coils in them that don't like being clouted, if the trigger wheel or magnets have been making contact with the sensor they fail... A loose connection could also do this (the vibrating wire would initially cause a haywire signal as you describe).
tks
posted on 31/12/07 at 03:39 PM Reply With Quote
it depens on the type of sensor tought...
if its a reed sensor it will work when you put it close to a magnet (stays open/clos)
if its with coils its hard to test it.
if its inductive you can test it stationairy..
Tks
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
posted on 31/12/07 at 05:51 PM Reply With Quote
thanks guys
looks like a new sender then, the only
problem the is how to stop vibration?
I had sender mounted on chassis picking up signal from propshaft bolts, cap head so distance was uniform, Sierra diff also mounted in chassis !
I had thought it had been hit by bolts, perhaps just grazed and damaged it. basically more outlay!!
