Author: Subject: 10 or 12 volt ?
Scotty
posted on 3/5/08 at 09:31 AM Reply With Quote
10 or 12 volt ?
hi
quick (and possibly stupid) question
rover v8, is it a 12 volt coil required or 10 volt ?
some one has put doubt in my mind and now not sure
if there is a choice, how/what do you look for to confirm whats needed
cheers
scott
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
Macbeast
posted on 3/5/08 at 10:57 AM Reply With Quote
Depends on the wiring really. If this is complete car the existing coil should say o n it. There may be an obvious dropping resistor (white ceramic block, one wire at each end ) or the dropping resistor may be hidden in the loom, in which case it's difficult.
I'm afraid the manual is your friend here.
If you just have the engine and are wiring up your own loom go for 12V and no dropper.
Scotty
posted on 3/5/08 at 06:51 PM Reply With Quote
cheers mate
as its luego loom , will be easy to bypass
thanks
