prelude1980
posted on 21/6/08 at 11:45 AM |
Side lights and Dip
I've had the car going since november but i have the side and dip lights round the wrong way on the stalks, I just started to fit the wipers so
thought i'd fix it but i can't figure out whats wrong.
I have BG87 stalks and a premier loom.
one the first click of the switch i get dip and side lights
on the second click i get side only
any ideas?
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
tks
posted on 21/6/08 at 12:01 PM |
well you are making the wrong relais...
cant you just turnaround/swap the relais connections..??
Tks
prelude1980
posted on 21/6/08 at 12:27 PM |
sounds like a good idea but side lights are thru a relay
gets you.
austin man
posted on 21/6/08 at 07:17 PM |
I think the previous post is suggesting you need to switch the connections on the relay to get around the problem. Check the wiring diagram in the
sierra book, if I can reacall both switches connect differently think one has something to do with the earth. But wires aint my thing
prelude1980
posted on 22/6/08 at 03:31 PM |
i've been messing all morning checking the wiring, i got it to work correctly now, there are two flat spade connectors but when i plugged it on
the other one it works
gets you.
