<<  1    2  >>
Author: Subject: Aldi Action Cam
posted on 28/12/09 at 02:16 PM Reply With Quote
Originally posted by leemarkadams
... I thought it was good value for money, just be aware that they use the batteries very quickly!
Sounds like a pack of rechargeables would be a good investment!
scutter
posted on 30/12/09 at 01:34 PM Reply With Quote
OK, i'm a numpty, must stop looking in lidl for aldi cameras .
Does anyone know where the mic port is so i can cover it? The noise it picked up just from handling it doesn't bode well for being out in the wind on my rollbar.
ATB Dan.
posted on 30/12/09 at 07:41 PM Reply With Quote
Looking at the front, it's the black wedge-shaped thing on the underside, below the lens on the silver part.
I have no great expectations for sound - I'll probably put some foam over it, but most likely I'll just manage without.
karlak
posted on 31/12/09 at 04:57 PM Reply With Quote
Got one of these up today.
Quick question -
You guys that have one. Does the LCD display light up when you switch it on? The manual says that the LCD will "light up", but mine does'nt.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
posted on 31/12/09 at 06:28 PM Reply With Quote
No, mine doesn't (and it's bleedin' hard to read too!)
ReMan
posted on 1/1/10 at 10:21 AM Reply With Quote
Quick question -
No it "comes on" but is not backlit
RichardK
posted on 1/1/10 at 11:08 PM Reply With Quote
Just go into the menu and turn the sound function off! If you don't want sound. Its in the manual
Unless you just want to quiet it down a touch then I'll let you off
Rich
Gallery updated 11/01/2011
Danozeman
posted on 2/1/10 at 03:19 PM Reply With Quote
MM might have to see if my aldi has any left. That is if its still opn it is due to shut.
Dan
posted on 2/1/10 at 03:22 PM Reply With Quote
The important trick is not to buy it with high expectations - it's a very basic camera that takes video that's of an "acceptable quality", no more, no less.
The big thing in its favour is that it's tough, reasonably water-resistant, simple to install and reasonably easy to use (if you can read the damn display!).
<<  1    2  >>
