<<  1    2  >>
Author: Subject: zetec TBs
alawrence
posted on 11/11/10 at 06:16 PM Reply With Quote
david,with regard to bent runners is there a performance draw back to this ?
flak monkey
posted on 11/11/10 at 07:37 PM Reply With Quote
Only very slight, on the road you probably wont even notice the difference.
Sera
http://www.motosera.com
alawrence
posted on 12/11/10 at 05:44 PM Reply With Quote
are there any connections /or sensors needed in the runners that need to go into the ecu...omex or simillar
flak monkey
posted on 12/11/10 at 07:05 PM Reply With Quote
Not particularly. Vac signal can be taken from the connections on the throttle bodies themselves.
Air temp sensor can either be fitted infront of the throttle bodies, or fitted in a boss in one of the runners.
All other signals are taken from elsewhere.
Sera
<<  1    2  >>
