blakep82
posted on 19/1/11 at 03:12 PM |
quote: Originally posted by RazMan
quote: Originally posted by PeterV
If memory serves the IVA states that the DRL's must turn off when the headlights turn on so I guess that means they have to be independent
units. Pure madness!
Not really mad as DRLs have a much wider beam spread so they would just dazzle at night. A bit like the difference between rear foglights and tail
lights
brilliant, so i can drive with my fog lights on all day then
________________________
RazMan
posted on 19/1/11 at 03:42 PM |
I am pretty sure the BIB would disagree with that
Front foglights have a defined beam designed to penetrate under the fog.Rear foglights are designed for use in bad visibility conditions only but many
people use them 'illegally' and forget to turn them off when conditions improve (worse than leaving fronts on IMO).
Headlights have a very defined, forward facing beam and are practically invisible in daylight if viewed from the side.
DRLs have a light which is diffused in all directions and so have a much wider angle of view. In theory this means that the stereotype myopic old lady
will still see the car in broad daylight.
Raz
mogman1969
posted on 19/1/11 at 04:18 PM |
i wonder if volvo engined se7ens ..........you can see where im going with this
PeterV
posted on 19/1/11 at 05:39 PM |
