craig5
| posted on 20/6/15 at 09:11 AM |
My main issue it says rev cable should be just wrapped around spark plug wire mine is soldered
CosKev3
| posted on 20/6/15 at 09:28 AM |
no thats for engines with one piston, it says connect it to cylinder one coil on engines with more than one piston.
try setting up the rev counter as in the manual before taking wires off and rewiring
craig5
| posted on 20/6/15 at 10:01 AM |
Told by ex owner was worrying fine until last few months
craig5
| posted on 20/6/15 at 02:07 PM |
ive got the speedo working its a little out so redialed a wheel length but cant check due to weather but have noticed the clock keep reseting its self
to 0:00 could there be issue with head unit as its holding other setting? anyone got advice regarding the waywould revs?
CosKev3
| posted on 20/6/15 at 02:13 PM |
Have you tried the different rev settings in the clock?
Because my coil pack does two cylinders I had to set the rev counter up to the two cylinder setting in the clocks, also you can choose positive or
negative feed types.
craig5
| posted on 20/6/15 at 02:19 PM |
It's set up for 4 cyl and piston 1 and hi
CosKev3
| posted on 20/6/15 at 02:22 PM |
Do your coilpacks fire two cylinders?
If so try setting for 4 stroke 2 cylinder
craig5
| posted on 20/6/15 at 02:29 PM |
There are 8 connectors in total if that helps?
craig5
| posted on 20/6/15 at 02:38 PM |
Just tried 4c 2p and still same
craig5
| posted on 20/6/15 at 06:49 PM |
sorted speedo and revs :-)
CosKev3
| posted on 20/6/15 at 08:01 PM |
what was wrong?
craig5
| posted on 20/6/15 at 08:10 PM |
got speed sensor around 4mm from magnet and diameters was out took a rolling diameter of wheel and put them into setting now within 1mph of sat nav
craig5
| posted on 20/6/15 at 08:12 PM |
The revs I completely removed the koso wire and replaced with a shield heat resistant core cable and is perfect now
CosKev3
| posted on 20/6/15 at 09:35 PM |
Ah right nice one.
craig5
| posted on 20/6/15 at 09:45 PM |
The cable koso give you is not fit for purpose my mate who's a instrument tech was very surprised how poor the design is
daniel mason
| posted on 20/6/15 at 10:30 PM |
We'll done Craig! Not bad after only 2 days of ownership! You'll be doing more and more to the car as things progress and you progress as
a driver!
[Edited on 20/6/15 by daniel mason]
craig5
| posted on 20/6/15 at 10:37 PM |
I'm really anal with cars they have to be right I can do anything machanical but electrics not my strongest points but I am relentless :-)
daniel mason
| posted on 20/6/15 at 10:45 PM |
A good attitude to have! Once you've done some track work,you'll be desperate to compete in it! It will be a very very quick car
craig5
| posted on 20/6/15 at 10:58 PM |
Not as quick as my impreza haha or my ducati
daniel mason
| posted on 20/6/15 at 11:01 PM |
Should be on another level to the Impreza on hills and sprints, and depending on the spec of the Impreza I'd imagine on track too
craig5
| posted on 20/6/15 at 11:08 PM |
I'd say impreza much quicker it's nearly 600 bhp
craig5
| posted on 21/6/15 at 07:47 PM |
have double shielded core today now revs are perfect so if anyone needs parts or help with this issue is be happy to help
