<<  1    2  >>
Author: Subject: Infuriating problem when starting....
posted on 2/3/17 at 08:19 PM Reply With Quote
for best starting, you should have cable from battery - to chassis and then another cable from that point to the starter motor.
from the symptoms above, it does sound like there was a bad contact - the metal contacts have to be in top condition as the starter can draw in excess of 100 A and any high resistance, even fraction of an ohm, will drop voltage and hence power to the starter.
also clean the positive cables to ensure there is good contact.
lordbenny
posted on 2/3/17 at 09:03 PM Reply With Quote
Thanks for your help everyone
[Edited on 2/3/17 by lordbenny]
<<  1    2  >>
