cossiebri
posted on 17/4/07 at 03:01 PM |
Where from? & where to?
how many??
If it doesn't fit MODIFY it!!
Cheers BriF
Colnago_Man
posted on 18/4/07 at 08:22 AM |
The main engine earth point on your engine should be next to the oil breather pipe on top of the gear box casing. It may just look like a tapped hole
if its not being used at the minute. I would take a -ve lead to this straight from the battery from here. Although if your engine is turning over
I'am not sure if earthing is your main problem.
cossiebri
posted on 19/4/07 at 08:14 PM |
Checked all the earth's no probs there.
Just ordered a new pulsing coil, been told by a bikeshop 'leccy' they are fragile and prone to breaking down.Not to bad only £35+vat new,
Just another piece in the puzzle???
Cheers BriF
roadrunner
posted on 20/4/07 at 11:26 AM |
Well, any luck yet, by the way did you bridge the clutch switch, i have done on mine, but have'nt tried it yet.
Brad.
cossiebri
posted on 20/4/07 at 02:47 PM |
Part on back-order
If it wasn't for bad luck i'd have none at all
Yes bridged the clutch switch(another way to do it is earth the green/black wire that goes from cdi to junction box)this also defeats sidestand switch
Cheers BriF
cossiebri
posted on 25/4/07 at 05:20 PM |
Replaced the pulsing coil, and NOTHING Really getting annoyed now,still no spark
Ideas anyone,anyone want to have a look?
Cheers BriF
posted on 25/4/07 at 06:05 PM |
im devastated for you bri, wish i was closer to have a look at it All i can suggest is start at the top, read the diagram and follow every wire. I
bet its a simple oversight or a loose connection. You sure the cdi isnt cooked?
cossiebri
posted on 25/4/07 at 06:25 PM |
I managed to get another cdi, also replaced the wiring harness. Needs some fresh ideas?
Cheers BriF
roadrunner
posted on 25/4/07 at 08:59 PM |
what about the starter relay, or any fuses, bike and car looms, do you have the zx9r wiring diagram.
